Rewire Fuel pump what amp in the fuse holder should i use!?????
JoEgsX90
183
Jun 10, 2006
Yon, New York
Whats going on guys, have a rewired 190 fuse pump, that was already installed in my gst . The power wire on the rewire was tapped into a thick aplifier system wire that was coming from the battery to the back of the car. It also has a fuse holder near the battery what AMP fuse should i be putting in there????????????? Ask because fuse holder was cheap as fk and broke getting new one need to know what fuse
15 is likely fine for a 190, but you could throw in a 20 or 30 and be fine as well... I use a 30 for two 255's though since they draw around 12A a piece full out. I use an ANL fuse holder like this one:
http://carjamz.com/zen/images/FH0ANL.jpg
works great and was only like 7$ or something. Better then shitty blade fuses.
