fuel pump fuse 1g rewire
davidgt97
97
Jul 13, 2007
eastview, Kentucky
I have done the pump rewire on my car but my fuel pump does not come on. I have checked the harness hot wire and there is no voltage. i can not find the fuse (93 awd). Any ideas?
I am refering to the original fuel pump hot wire (black w/ stripe) I cannot find any fuses that say fuel pump.
That's because your looking for the wrong thing. The stock fuel pump power comes from the 30A Ignition fuse on the positive battery terminal.
When are you checking for power on the black/white wire. The fuel pump is only activated during cranking and while the engine is running.
Steve
thanks for all the input. I do have the car running now (thought the pump ran when the key was on), but I have a much worse problem: see "a depressing story."
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
