Reverse lights not working.
white_dsm
Banned Member
230
Feb 9, 2008
Plains, Texas
Fuse is good, bulbs are good, really don't understand how the switch would go out but if someone knows any other ways this can be faulty lmk.
had the same problem. disconnect the switch plug, Then jump it with a wire if its the switch the lights will light up. The switch went bad on my 96.
Alright, jump the connector or the connecting piece?
Once you unplug it(the switch is on top of the tranny). Take the plug(not the plug on the switch, rather the plug on the wiring harness) and stick a wire in both holes to complete the circuit. If it your reverse lights come on then the switch is bad. When you go in reverse do you hear any noise like maybe a clicking? thats what mine sounded like.
I knew where the switch was at but just wanted to clarify which piece I jump. I don't hear any clicking but let me go do this and I'll post back.
