reverse lights not working
sway2this
60
Jul 1, 2004
kentwood, Louisiana
i was just curious as to what could be keeping my 96 eclipse gs revers lights from working?
please help me out guys.
charles
i had the same problem. check your bulbs, fuse, and if those are good then it is your back-up switch. the switch is on top of the transmission case and is really easy to change out. i bought mine at the dealer, but you can also get them at autozone for around 20 dollars. If you need more info pm me. hope that helps. :dsm:
