[RESOLVED] What is this piece and where can I get it.. (skirt front fender cap)
GSeX02
96
Aug 23, 2008
North/Central, New Jersey
That side skirt piece is off on the passenger side.
It looks like it goes in with a screw or something... anyone know where I can get 1..
the car is a 95 GSX..
It doesn't look 2 bad with it missing - not too noticeable but if you look or know 2gs like we do. I just got the car and realize it wasn't on.
Thanks guys
i didn't order yet. thank you. I am hoping a used 1 pops up maybe =\
would right be passenger side???
The pink dot is not for a screw, it is for a clip. There is 1 screw on the underside of the cap, and 1 Clip on the side where that pink dot is.
JNZ Tuning Ground Effects Clips
(JNZ has really fast shipping usually and I have ordered from them many times)
You will need atleast 1x of #9 and most likely need atleast 1x of #10. #10 goes on the underside of the body into a square hole in the frame. This is the hole that the screw for the under side will go into. Without this retainer you won't be able to put the screw in to hold the panel on. I bought 20 of each because it is nice to have spares and if they stop making them for some reason you are screwed. The side clips break really easily if you ever remove the skirts so you will want spares of those.
Comparing from what the guy on dsmgraveyard told me I would need:
1 #10
2 #9s
1 #6?
How i got those things is based on what the guy at dsmgraveyard wrote:
DSM Graveyard - Your #1 Source for Used DSM Parts!
Ok, I found some more info:
Part # ending in:
120 you need 2
578 you need 1
174 you need 1
is part #174 on dsmgraveyard the same as #6 on JNZ?
and the rest matchup?
1 #10
2 #9s
1 #6?
Part # ending in:
120 you need 2
578 you need 1
174 you need 1
Looks right, I don't know about the screw to be honest. The grommet is plastic and I'm not sure if it is threaded or not. That screw may work by making its own threads (since the plastic is soft),but it might be easier/cheaper to just go to the hardware store once the grommet comes in and see what fits. I don't know if the diameter of #6 is too big/small either.
Be sure to read what I wrote about JNZ shipping prices in my PM.
I ordered 1 fender cap for my 2GA skirts from JNZTuning also very fast shipping indeed! And cheap.
You can all ways find it on ebay too.:thumb:
eBay Motors: Mitsubishi Eclipse Side skirt: 95 GST, great for RS car (item 290275413397 end time Nov-21-08 17:13:55 PST)
The link I posted is a whole set of 2ga side skirts, I couldn't find just the end cap today. But if you keep watching you can find them on there and sometimes really cheap!
(the guy obviously doesn't know a lot about dsm's because in the listing it says that they came off a GST, when every one here knows that the gray at the bottom indicates GSX!!)
So the reserve might be low , if the guy doesn't realize what they are worth.:tease:
