General [Resolved] VR4 EPROM ECU in a 1g or 2g?
jetdriven
110
Jul 26, 2003
Houston, Texas
Will the ECU out of a VR4 work in either the 1g or 2g?
I have one that has an EPROM and wondered if anyone has tried this as a solution for the 2g guys who (I think) have a tough time finding EPROM ECU's??
If you're referring to the Galant VR4 ECU, it will plug into a 1g but it uses a different MAF sensor. You would need an SAFC, a chip, or DSMLink to be able to run it with no problems. If you were to use it with no tuning methods, it would run pretty lean compared to a stock ECU.
GVR4592 said:
If you're referring to the Galant VR4 ecu, it will plug into a 1g but it uses a different maf sensor. You would need an Safc, a chip, or Dsmlink to be able to run it with no problems. If you were to use it with no tuning methods, it would run pretty lean compared to a stock ecu.
Yes, I'm referring to a Galant VR4 ECU. Thanks for the response.
Will it work in a 2g with DSMlink?
