[RESOLVED] SS Lines
nytescion
602
Jun 25, 2007
Woodbridge, Virginia
Trying to find a place thats sells SS line -4an preferably. Was going to get it from extreme psi but they don't list it? also prefer not to have any fittings on it but if they have to have it then so be it..
Do you understand how stainless braided lines work? You have to use AN fittings with them. The only exception that I know of is the return line. You can hose clamp the return line onto the stock line without problems.
The lines can hold a great deal of pressure. Up to 100PSI or so for the rubber lines and lots of pressure (clutch, brake amount pressures) with the teflon lined lines with appropriate fittings.
These AN lines are no joke. They arent hard to figure out and work with, but if you dont understand something just ask before you order!
Check out ANplumbing.com. They have never failed me. They call me and talk to me about plumbing problems I may have, and always make sure Im up to date on my order. Call the tech line if youre lost and they can walk you through it. If youre confused, just post back.
EDIT - ^I wouldnt go there. Hit up ANplumbing.com, its what they specialize in and great prices.
I'm hoping he knows he needs -an fittings. But, i love ss lines, they are nice and easy, durable, and a guarantee basically that your shit wont break. Im going to be using all ss lines for my fuel, clutch, and brakes. Can't wait. Looks so fresh and so clean
James :laser::talon:
I think theyre a rip off i got a SS oil return line and all it is, is a rubber hose wrapped in that stuff..
That's the way all SS line is (except some stuff has Teflon line inside the SS outside). The reason that they are better is that the SS part doesn't let the rubber/teflon inside hose expand as it normally could/would without the SS. This is especially noticed in brake lines and the clutch line.
