SS lines
DSM MAN
466
Aug 28, 2004
Near Sacramento, California
I cant seem to find any stainless steel oil return/feed lines for my 14b turbo. May seem stupid to put them on a stock turbo but they are in need of being replaced and I might as well get stainless right? Anything i would need to know that would be different then a normal line? All help is appreciated thanks in advance. :thumb:
whats wrong with your stock ones? are they kinked or bent?
If your stock ones are leaking at the banjo fitting, all you need are new copper seals that go on each side of the line.
No they are completely covered in oil. The place i took my car to get my timing fixed told me that the return line was bad. I looked at it and its covered completely in oil, but the place i took it to tried to rip me off i think so im not sure at all. Im sure its fine because i have a pretty good size leak coming off my valve cover gasket that i plan on fixing soon. Thanks.
Not to sure. I cleaned it off a little today. But it was so thick on it. Also, where it goes into the turbo there was oil and it didnt look liek it could have come from the valve cover gasket leak i have. Idk. What do you guys think? Thanks.
