[RESOLVED] Quick ? about swap
RedEyeBanDiT
206
Dec 4, 2006
Rowley, Massachusetts
I know that 90 &91 had 6 bolt motors. I have a 92 and am going to put a 6 bolt motor in it, my ? is will everything be plug and play and will the clutch from the 7 bolt right in? thanks
First you need to check if the 92 turbo car you are putting the 90-91 motor in is a 6 bolt or 7 as some early 92 models were 6 bolt as well. If it is a 6 bolt everything will bolt right in. The clutch for the 7 would work with the tranny but not the motor so obviously you will have to use a 6bolt clutch and flywheel as well. Hope this answered your question.
It doesn't matter if the clutch is 6 or 7 bolt. It bolts to the flywheel. So just the flywheel HAS to be a 6 bolt. Everything else should be "plug and play"
Alrite Great guys thanks alot.
The motor was a 7 bolt that threw a rod. So all i need is a complete motor and awd flywheel and im all set haha.
  • Wanted 6 bolt NT water pipe
    • chrisman287
