[RESOLVED] power mirror fuse
greentalon03
44
Feb 4, 2005
new castle, Pennsylvania
both of my power mirrors quit on me at the same time so i replaced the switch and they still dont work any 1 know what fuse they are run off of because i no fuses are designated for the mirror :cry:
alright after aday of screwin around with the test light and tracing wires i found the fuse! its up under the dash all by its self...actually theres 2 1 feeds into the other for som reason it looks like but i changed the blown one and it works now.....so ive seen posts b4 on this with no replies so i figured id post.... theres a plastic bracket up under the dash it has 2 fuses and 1 relay in it just crawl under and look straight up.. shouldnt be hard to find :thumb:
its on the driver side like above the other panel.... its not on the fire wall tho its actually up under the dash
congrats on fixing it yourself. mine have been broken for almost a year, im the only one that drives the car though and they are set perfect for me, so never worried about it. now that the car is down getting awhole bunch of stuff done to it, i have fixed the mirrors though :thumb:
I know that this is an old post but I am having the same problem in my 2gb gst. I will check for the fuse location you mentioned and if my camera allows take and post pictures so that anyone else can find it with ease.
Update* not so easy. I believe that I have located the area greentalon was referring to but at this point it has more than 2 fuse slots although mine only has 1 fuse plugged in that I can see (red). I have gone through both of my manuals (chilton and haynes) with not much help with the location of the fuse. I guess trial and error will get this one done. I will post back when I have it solved and post pictures.
Fuse is high up under drivers dash here: http://www.dsmtuners.com/forums/atta...8&d=1269647021
From "luv2rallye"
