[RESOLVED] p1400 code ... need help!!
i was relocating my battery to the back and in the process i damaged two wires from the harness in the engine bay...i reconnected them properly so to not short anything out...but when i drove my car i got p1400 (manifold differential pressure sensor circuit malfunction. ) could it be i didnt fix the wires right or do i need a new map sensor?
how can i test the sensor to know its bad?
if i need a new sensor where could i get one for not to much?
thanx in advance
:talon:
well you could put a new one in and if it works it works, otherwise you can sometimes test voltage across some sensors
