[RESOLVED] Oil pressure problem please help... FAST!!!
91DSMdave
223
5
Jun 23, 2009
Strattanville, Pennsylvania
last weeek i was going to wyotech for a little show n go. on the way there my stock oil return cracked and i had to turn around and go back. i cut it and put rubber hose where that flex piece was. on tuesday i noticed my oil pressure was way below the normal line at idle like halfway between none and normal and when driving it would only go to almost normal but not quite. then sometimes it would go to mormal maybe a hair above, but no farther. then i went down a hill close to my house, 3rd gear 40 maybe 45 and my oil pressure went up to where it always is halfway or a lil more between normal and high. i have the stm bal shaft elim kit. it dont smell like oil so i dont think its leaking. could the oil pan be dented too much to the point the pick up is sucking against the metal? idk what to do. failing oil pump? HELP!!!
dave
to me that oil pressure gauge is about as worthless as the stock boost & fuel level gauge imo. the only stock gauge i watch is my coolant temp and even then if im skeptical i check my logger. i know there a little bit pricey but why not replace your oil return line and see if that corrects the problem? or get an actual oil pressure gauge so you can see what its actually at.
:dsm:
I am having a similar problem right now. At idle the pressure drops and the oil light flickers but after i rev the motor it will go back up to normal. I checked the oil and I am not burning or leaking any. I will check the return line as well!
yea. i want to get an aftermarket gauge.but for now i just wanna see what i can come up with. (broke as a joke because of my car) also, my exhaust was leaking real bad at the header,and just now on the way home my cyl 1 tube broke rite around the weld where all4 came together. (pacesetter) could that have ne thing to do with it? im so confused... i was told that putting the rubber hose in place of the flex piece on the return is much better than stock which is what i did. no apparent leaks ne where, dont smell oil
more in detail...
when the car is completely cold (sat overnite) the oil pressure will go up midway between normal and high where it is supposed to be. if i give it any gas or move the pressure goes down below normal and sometimes it almost saysno pressure and sometimes it almost gets to normal, but as soon as it is warm it will never go up past normal. unless im going down a long hill sometimes it will
