BOOST problem help fast please
NeOzz1
210
Oct 29, 2003
Wellington, Ohio
I purchased the dejon tool mmi dual stage boost control. It work fine for a while, but now my boost is stuck on high and i cant even adjust it. Its still getting power when i turn on the switch and the power turns of when i turn off the switch. I tried to adjust the high set screw to turn it down but it wont change even when i do that. I had the control mounted up against the radiator hose and i thought maybe it got hot and screwed something up but i am completely lost and dont know what to do or to look for. Please help and IM me if u think you know whats wrong.:(
take the screw all the way out and make sure the spring is not stuck on the threads inside. Mine has done that b4.
nope not the problem....... i called dejon tool and they said my valve is probably stuck and to send it back and they will replace it
