Boost Problem! Please Help...
1990TalonTsiAWD
Jan 13, 2012
La Crosse, Wisconsin
So i have been having a problem the last 2 months that has made me really mad.
I have yet to find anyone with the same problem.
What happens is when i start my car and let it warm up it runs great at an idle of around 1000 RPMs.
Then i take it out and for the first 5-10 minutes it will boost great and run like a champ.
But after about 10 minutes of steady driving it will only let my get to 5 pounds boost. And when i try to go over 5 pounds it looses all power.
Like it seems like the boost will just totally cut out.
Then after about 25 minutes i have absolutely ZERO boost.
So i have to just crawl up to speed or else the car will not go.
The weird thing is when i let it cool down for 10 minutes then drive it again it seems to get better.
I'm guessing it could be a seal somewhere or gasket that is getting too hot and causing a leak, but where would it be that it leaks all boost that quick? (INSTANTLY)
I have done a cold engine and hot engine boost leak test and fixed a few bad hoses but it still does this.
the only thing i notice when we hot test it is there is a high pitch whistle coming from the front of the engine but i can not pinpoint it.
also i replaced the spark plugs and it did nothing. (alot of people said that would be the problem)
the car is a mod free 1990 talon tsi
any help would be highly appreciated!
The high pitched whistle your hearing could be a leak near the compressor housing on your turbo possibly your J pipe.
well i got to to it and there is no shaft play whatsoever and the inside looks very clean...there was a little oil on the outside of the pipe but i used to have and oil leak above it awhile ago so i think its just residual oil from that. so does that mean the turbo is still good? just so i can for sure cross that off the list...
also on thing i noticed was that the intake hose wasn't really tight..going onto the turbo...could this be a factor? and if so why would it only leak boost after driving for awhile?
I'm still new to these cars so I'm not sure if this would make sense but, you said you had an oil leak and there was oil in your intake. Is it possible that you have a bunch of oil in your intercooler clogging it up and your just heat soaking??
i have not not done either..im still new to cars and have not gotten far with it yet...i will probably have too cause i am still clueless whats causing this
yeah i can spin it with my fingers and its not rubbing on anything...and its not spining hard at all but it has a little bit of restriction...sort of like a rubber band is hooked up to it...
hmm.. you dont have an extra one laying around? or a buddy with a 14b u can test with just to check.. also get to the bottom of where the whistling is coming from and do the comp and leakdown test's.
well i tighted down everything i could and took it out driving and i couldn't notice any boost problem anymore...i haven't had a chance to drive it for like 30 minutes so im not totally sure if its fixed but i could see the turbo was getting to full boost way faster..i think the problem could have been the intake hose that connects to the turbo because the clamp the was on there didn't tighten down hard enough so i put a better clamp on there..
thank you to everyone that helped me out!
it was nice to be getting advise while working on my car...
i will definitely be back on here alot more and let you know if the car continues to run like it should.
two thumbs up!
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
