[RESOLVED] Oil pressure low?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
Ok ill try to explain this the best i can.
Well i start my car and the oil gauge go's about 2/3 then after it starts to warm up it will drop. and i press on the gas and i can see the gauge rise then i come to a stop and it will drop fast to about 1/6th of the gauge its pritty close to the L. then all i do is step on gas and it will jump up to about 3/4 and drop back down to just about the L. i checked the stick and the oil is fine. is this just a normal dsm idle? 91 eagle talon tsi awd
Also, My car has been smoking for what i think is water and a lot of it to. if i drive it around pritty hard for 10 mins or so it will stop for the most part but its smokin a butt ton thanks.
what kinda of oil do you use ???
synthetic or conventional ....
and what weight ?
5W-30, 10W-30, 20W-50 ???
My oil pressure does that. I'm not real worried about it, because I know I could use new rings. Where is the smoke coming from and what color and smell? Could be lots of things without more info.....
SEA 10W-30 castrol GXT oil =O i thought i should go all out if i tell u
thats about right for weather 60 F-90 F .....
for colder weather 50 F and below ...use 5W-30 .....
and for summer 100 F + ...maybe use 20W-50 .....
and its normal for your oil pressure to fluctuate high/low...
