63tuner
- 39
- 0
- Jun 10, 2008
MAS,
Asia
my car seems to missfire at idle, but it happened when i drive it for more than 30 minutes. And when i drive at about 60 mph using gear 4 and 5 and then push the throttle, the car seems to hesitate with the RPM moves slowly up. I noticed that my AFPR reading sometimes went down from where i set it (from 42 psi to 35 psi) but when i pull the vacuum line at the top of AFPR, the idle went up..I have a white plug tips on the 1st cylinder.
here what i did to overcome this problem
1 clean the throttle body
2 clean the PCV valve
3 new gasket at TB and BOV
4 teflon tape at sard AFPR ( @ adjustment screw, gauge) and @ the type s BOV
5 new plugs (NGK BPR7EIX) (gap @ 0.026)
6 check for boost leak using soapy water
7 used the injector cleaner
