cylinder 2 missfire
JayB98GST
72
Aug 20, 2002
ok, at high boost and high rpms i get a missfire that lasts about 30 seconds or so after i let off the throttle. i got the cel pulled and it says cylinder 2 missfire. so i did a boost leak test and it sounded like there was a leak coming from the #2 injector seal. so i changed the seals and it seemed to help a little but i'm still getting a missfire. then i did another leak test and now it sounds like there is a leak somewhere under the valve cover. I just had the head rebuilt and the bottom milled and a new head gasket. anyone have any ideas what else might be causing this missfire problem? thanks in advance.
If you do a boost leak test from the compressor opening on the turbo then you'll hear air leaking out. Do the boost leak test from the lower intercooler pipe for more accurate results.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
