Cylinder 3 missfire?
overboosted1g
743
6
Jan 13, 2010
washington, Michigan
So my 2g tsi has a 1g 7 bolt head along with a black top cas and a 1g coil pack. Before I was having a problem with the random missfire code, so I did the pot mod and the code went away. Recently I have been having a problem with cylinder 3 missfiring. I can drive around the city all I want without isuses but as soon as I jump on the expressway and drive for 10-15 minutes the car will start to missfire and run like crap until I clear the code. I have replaced the coil and plug wires and the plugs have less then 1000 miles on them. What could it be?
Sent from my SPH-D700 using Tapatalk
The car has rc550cc injectors fuelab afpr and -6an feed line from tank to rail safc comp cams 262/264 bc retainers and springs felpro headgasket and arp studs
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
