[RESOLVED] lights gettin bright n dim
eric62810
34
Apr 24, 2008
belle rive, Illinois
hello ive had my talon for about 3 years i know a lot about it :thumb: but aparently not enough :confused: i just rebuilt the engine (90 gst 6 bolt} :D it starts and runs great but for some reason when the car is running all my lights go from bright to dim and back to bright again it does it very rapididly and continuous ive checked all the wireing under the hood and on the alt ive checked to see if the alt charges witch it does ive put a new bat in ive done every thing i can thnk of but i cant find the cause has n e one else had this prob and if so how can i fix it thanks for the help in advance for whoever can help eric
When my car did that, it turned out to be a bad voltage regulator on the alternator. See if you can find a used or remanufactured one that you can test on your car to see for sure. Alternatively, you can take the alternator off and bring it to almost any auto parts store for free testing on a bench tester.
Have you seen a 4g72tt in a tsiawd? any info on it... I may have found one ecu wire harness all... let me know
6g72tt but i think ya knew what i meant. sorry
Thanks
ive had it checked at two diff locations n both say its good i have a capacitor for my stereo n reads n-e where fromm 14-14.5 all the time however the the stud that holds thae wire on does spin could this cause and if so ow can i fix??
FIXED!!! THANKS FOR THE ADVISE GUYS IT WAS THE STUD THAT THE WIRE WENT ON IT WAS LOOSE AS HECK ILL GET SOME PICKS SOON ON THE SITE SO U CAN SEE THE CAR THANKS AGAIN GUYS :talon:
