[RESOLVED] I did something stupid. question about transmission fluid
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
Well I was putting the car back together last weekend I had to put the new friction plate, Clutch and then put the transmission on. All went good with that but I wasn't paying attention when I put the transmission lube in.
I had the front of the car jacked up so I can crawl under the car and filled the Trans up with redline MT-90 and I know the transmission only takes 2.3Q and It took 3 quarts of lube. My question is is that okay or do I have to drain and refill?
No I will not drop some then check blah blah blah I want to do it right so I ask you.
