[RESOLVED] HELP diagnose a no start I have tried everything. videos
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
as most of you know my merkur of the mitsubishi world stranded me at the gas station last wed.
So I have no spark so I thought on my talon (well no spark on number 1 cylinder) well I got a new/used Power transistor thinking that was the issue. Guess what? No its not. I changed out the cas for a good working cas and nothing. I changed the coil for a working coil and nothing.
So I changed plug wire number 1 and nothing
So I changed the plugs nothing
Changed that fuel box on the firewall nothing.
I hooked the computer up to the car and turned the fuel pump on which you can hear when you turn it over.
I have no idea were to start.
It has a newer fuel filter (maybe 1k miles on it) but when I finished the build on the car there was roughly a half tank of e85 mixed with 93.
Okay, Well I pulled some fuel from the return line to see if any water is in the system and no dice.
But I pulled the ecu and that looks like my problem.... I'm not going to write this one resolved yet but I'm willing to bet it is
Well I got this ecu at a junkyard for free and it worked up until I got dsmlink so when I sent it to get socketed and had it rebuilt the guy that did it (done plenty of ecu's for tuners on here ) said one of the traces? were bad and he had to run a wire under the board. So he told me that he didn't know how long it would last. He said it could last forever or a week.
looks like I should just get a new ecu.
Yeah well they are not shipping until july 7th and I need this thing now. It's okay when the fiance isn't at work because I can take the honda but shes at work and I'm stuck at home. I cant even go to the pool to check out the hotties...
resolved,
The ECU was bad. Swapped in another ecu and worked like a charm.
Now the new ecu needs caps replaced and the board cleaned up with a socket added.
I need this thing done ASAP. anyone around iowa that can do it?
I'd contact steve who's in Illinois.
I sent him another pm.
But by the cost of what he has on his website I should of just bought one of his ecus or one from mg motoguys because its going to cost me close to 150 for him to do his work and be with out a car for another week or so.
Okay car runs. Now its sells in 6 hours on ebay.
It was the ecu.
