soldave
- 737
- 1
- Feb 17, 2008
Okinawa, Japan,
Asia
Quick GM MAF question for you folks. Will be running the MAF in blow-through mode once it's all set up and installed. I'm going to cut the metal dividers as suggested but was wondering if I should keep or do away with the mesh that's in front of the sensor wires. It is a protector I suppose but then there shouldn't be anything in the airflow post-turbo that could hit and damage the sensor anyway.
So should it stay or should it go?
, no way. Best of both worlds. No need to tune for something as simple as an o2 housing upgrade, but still zero resistance to flow before the compressor.
