GSXeclipsePSI
- 563
- 7
- Jul 7, 2003
New Port Richey,
Florida
Ok... 1st to state I have researched and researched and checked and checked about this.
My car decided while I came to a stop, to stop going into gear. So I did the normal checks.
- Replace Slave (was damaged inside, and leaking)
- Bleeding of Clutch Line (I have SS used DOT4 Fluid)
- Adjusted M/C
- Checked Clutch Fork Alignment (PIC BELOW)
THINGs I NOTICED:
- When pushing in the clutch, the clutch fork stops before hitting passenger side of window, and you can see it hit the point (SEE PIC BELOW; RED LINE) when the fork stops moving, but you can hear/see the SS line taken more stress
- When driving, like maybe 20 miles b4 car wouldn't shift while on, I hear what sounded like the TOB Clip/Return Clip flew off. I heard a noise that sounded like a clip/round ring felt off.
- Right b4 it happend, I rev'd the car with clutch pushed in and the car moved fowards at round 6k. Didn't think too much of it tho.
- I was able to drive the car home. Turned car off, and put in 1st gear, and it shifted a few more times the 1mile to the house.
- When car is on, the car will creep fowards when trying to put into gear. Doesn't allow you to grind!
- M/C not leaking
- S/C did have marking on inside to hint debris
- When pushing clutch in, m/c does make noise like a like a bike pump, but faint I can hear it, other people can't.
- TOB did make noise, could only hear it in my garage tho.
- Clutch Fork is sloppy, flops around like a wet noddle. *SEE PIC below*
MODS/Replacement Times
(ACT2600, SS Clutch Line)
- Tranny is used, replaced maybe 9k
- Clutch is new 5k
- Clutch Replace w/6Bolt swap inspected TOB, seemed good had 9k on it.
TOB Not Replaced
- FLYwheel was resurfaced and stepped correctly
Clutch Fork
Sloppy Movement
* moves around all over the place, is this normal?
Ok, so now its up to you guys to help me out, I'm trying to avoid pulling the trannys as I have never done it b4 by myself always had knowlegable/expericanced people helping but I moved 1200 miles and they aren't around anymore. So the pics show you everything I can see.
Thanks guys,
Kendel
Tampa Bay, FL
- Adjusted M/C
THINGs I NOTICED:
- M/C not leaking
- Clutch is new 5k
TOB Not Replaced
Clutch Fork
Sloppy Movement
Thanks guys,
Kendel
Tampa Bay, FL
