2gboosted
- 47
- 0
- Jun 11, 2007
belle foruche,
South Dakota
ok i bought a 91 tsi awd a few days ago... i ran 91 like you should... for mods it has cat back, intake, safc, manuel boost controller, ported head, 4 angel valve job.... there probly a few others but i cant think of them right now...
problem 1- car died at almost every stop sign.... or when i slowed down
problem 2- i was driving it and i got cut of almost everything.... it wanted to die so tried to give it gas but nothing happend
problem 3- pulled the plug wires to see if that was the problem but it wasnt
so i pulled the spark plugs and found out the number 1 plug was burned to shit.....
problem 4- i then replaced the spark plug with the same one it had (waiting for the NGKs to come in) i here the fuel pump injectors and starter working it might get a couple chugs outa it then all you here is the starter *not firing*
problem 5- i pulled the upper timing belt cover off and the belt is all fury looking on the side of the closed cover side.... meaning im guessing it rubbed up against the chain thing lower down and moved the belt to rub up against the cover but its torn to shit.... belt looks fairly new... no major cracks that i could see.... ALL teeth are still there so i dont think the timing would have skipped...
problem 6- after changing out the spak plug i decided to see if shell start.... so i put in the clutch and i get a even weirder noinse (thinking its the timing belt)
problem 7- when i got on it a little bit i heard a wierd winding sound that was kinda loud i was told its normal and its from the T case
idk what it could be but basicly ill go to start it get a couple chugs then no firing up.... idk if i threw a vavle or bent one but from what im toled youd beable to here it if i did....so... ya.... let me know what you guys got...im in desperate need ofhelp....
