[RESOLVED] 2g power seats stuck up under dash!
95fwdtsi18psi
803
Jan 6, 2009
West Laffayette, Indiana
I took a break from my DSM for some of my other hobbies, but recently I decided to try and fab up some rear seat deletes for her, but didn't turn out good.
I had the power seats pushed all the forward so I could climb in and out of my car easily and now I believe the motor went out, and I can't get to the bolt to take it off the tracks because the seat is right over top of it. Any other way of removing a seat? Oh and I forgot to mention the stuck one is my drivers side seat, so I can't even drive her until it's fixed...:cry:
Anyways, any help would be massively appreciated. Pictures can be brought into play if needed, just ask.
Those front two "bolts" are actually nuts....loosen them as much as possible then lean the entire seat bracket and all, back as much as possible, might take a few extra minutes but it'll come out...
I've been to by luv2rallye that the power seat is fed by the power window fuse...May want to check it....
On a side note, there is a tiny whiteish plug under the seat not sure what its for but mine didnt work til I hooked it up...I had the rear 02 plugged in and another plug but I forgot that small little white plug, needless to say it didnt work til I hooked it up...Might want to check into it....
I fixed it, with a Sawzaw. I have been needing an excuse to get some decent seats and new carpet for quite some time, maybe this is it. Thanks for the input though.
