replacing blinker without removing headlight?
tg93gsx
Jan 23, 2003
East Lansing, Michigan
Hey guys, I just got a 95 Talon TSI, and was wondering if there is anyway to replace the passengers side front blinker without removing the headlight. I searched and that doesn't look like a lot of fun removingt the headlight unless I just rip it out, leaving the screw under the healight in. I'm gonna be mad if I have to take off the front bumper to just to replace the blinker. Thanks for any help.
i had 2 remove my headlight in my 2g i had, it wasnt that hard, but if i remember right,, if u get under the car, u can get to the plug in where the blinker is, just jack it up and take a look, u should see the plug in going into the headlight
Go through the access door inside the engine compartment. Remove the air cleaner housing to access.
Get over to eBay and pick up an Owner's Manual. And a shop manual while you're at it.
or you could just go at it with a sawzall. just remember to bondo and ziptie when done ROFL
ok, seriously.. I cut down my fender lining to open up air for the SMIC when I had one. if your lining is gone, you can easily stick your hand behind the fender and get hte bulb
