420A Replaced CV axles and now can’t shift through gears
3Starsearch
48
6
Feb 14, 2025
Las Vegas, Nevada
I replaced both front axles, drained and refilled 2.1 qts for my 420a manual. Started up nice tried to shift gears but couldn’t. I noticed it can shift after multiple attempts but only to reverse or first but it grinds. Whenever I attempt to shift car slightly moved forward and stops. I purchased GSP axles from Rockauto part numbers are NCV12541(Driver) and NCV12530(Passenger). It went in pretty smooth and tried to do more pushes but it sounded like it bottomed out so I didn’t wanna damage anything. Would like some info as to why it’s doing this
I would pull it back out and have a look at the splines to make sure they haven't sheared off. It definitely isn't seated. You can put some axle grease on the clip to make installation easier.
When its flush with the trans its in. Shouldn't be a big deal. Yiu dint have to pound it in. It goes until the clip seats.
Hmm okay I’ll double check again thank you. It’s just sounds concerning that any more push it sounds like I’m hitting the end of the transmission or bearing.
