420A Repetitive Misfire codes P0300 to P0305
ECLIPSEGS2
Apr 9, 2022
Lebanon, Indiana
I'm fairly new to DSM, just got a 99 gs 420a 5spd. However I noticed that the CEL/SES keeps coming on for multiple random misfires, and misfires on 1,2,3,and 4. I replaced plugs, wires, coil pack, and checked each cylinder for build up/ carbon. However whenever it pops these codes I dont feel any misfires but at low rpm below 3.5k rpm engine braking and light accel it pops alot. Im at my wits end for what could be wrong with it.
Codes P0300-P0305
I find it odd that your compression readings were 200+ on all 4 cylinders with a blown headgasket. Have you drained your oil and checked for coolant? And you didn't see any coolant in the cylinders?
The larger passages are the coolant passages and the smaller ones are the oil passages. It would be a unique headgasket issue to get oil in the cylinders but no coolant in the cylinders. And no coolant in the oil. It is definitely possible especially with the factory head bolt torque issues, but you see what I mean?
Oil pressure is forcing oil into cylinders
Show me where the oil can enter the cylinder without also entering the coolant.
Checked the coolant it is clean, used a scope and poked around in there, saw no signs of leaking valve seals. However I noticed a major oil mess on back of the head near Head and block are separated by the gasket spanning across cylinder 2-4 when running it became a seepy and started leaking.
