thebrownman1
- 67
- 79
- Feb 17, 2015
Medicine Hat,
AB, Canada
Bros,
I'm currently in the midst of a maintenance and upgrade blitz. One of my tasks is to replace the knock sensor because I was getting a ton of phantom knock and I want to fix it instead of trucking the ecu in link.
So I didn't realize this when I was installing the engine because I'm still somewhat of a noob but the previous owner destroyed the connector on the harness and hard wired it in all willy nilly.
The under the brown insulation on the engine harness are a white wire that has another braided wire around it. It's really half assed so I want to fix it right. How do I go about this? Should I just pull more of the braided wire out, solder and heat shrink it to black on the pigtail?
