Removing Throttle body oxidation
AlaskanDsm
1,124
17
Oct 21, 2007
North Pole, Alaska
Ok, so I have a second TB that I wanted to rebuild and I was going on vacation. the 2nd TB was dirty and I wanted to clean it and bought some simple green max. Well after asking around and making sure that that stuff won't eat rubber, I left the TB in the simple green while I went away on vacation. Well little did I know that Simple Green would cause aluminum to Oxidize and turn a horrid dark grey.... WTF
I am wondering what I can do to remove the oxidation as I cannot get a brush on the inside of the TB. It cleaned all the screws and stuff up pretty good and there was a lot of crap in the bucket too but I think I learned my lesson about this one. If anyone has any ideas on what I can do to remove this grey disaster, I would really appreciate it. I will try to post pictures later.
Some of the things I have found is to try using vinegar and water, mild detergents etc... but I don;t know how well it will work. I currently am trying to let it soak for a couple minutes in Cascade dish soap and water.
yea I wouldn't recommend letting stuff soak in Simple Green like that but I will look into theover cleaner but when I did some research, the lye in over cleaner when heated over time seems to have a problem with the aluminum. But bead blasting would be nice, I just don't have any way to do so. Sand paper, wouldn't be good as you couldn't get it all off. I can slowly get it off with a toothbrush but was hoping for some other method...
I would say bead blast it. Here's how well it worked on an IM...
mmmmmmmmmm looks soooo sexy!!!!!!!!!! :sneaky:
But I hope that they would be able to do that and clean up all the springs and everything as well. I just want the whole thing to look nice before I put it in my car.
Does anyone have any other suggestions?
Anything remotely abrasive that touches the polished precision area of where the throttle plate is will screw with how it functions. Well - depending how nuts you go with cleaning it.
I'd just take it to a reputable metal shop.
This is funny because I just took my throttle body apart and took the intake manifold off and cleaned them up, then painted them with Duplicolor's engine enamel "Cast Aluminum" and it looks EXACTLY like the "bead blasted" one you posted a picture of. Pretty good shit, that paint is.
Another vote for bead blasting. Here's how throttle bodies look after my brother and I are done with them (including all new seals and such).
damn that looks really good
You can always use an aluminum acid etch that is called "Aluminum brightener" from NAPA. I used it on my RVR intake manifold. Here are a few before pics. I can't snap any after pics right now because my sister is on vacation with my camera but it looks just like the bead blasted intake just more of a flat aluminum finish instead of a shiny aluminum finish. Plus it's only like 20 bucks for a gallon. Bead blasting is the way to go though. I will snap a pic for you when she gets back. LOL If she ever comes back.
Oh yeah I used it on my 1g throttle body but I ran out of brightener so it still needs work.
Surprisingly a highly abrasive toothpaste works quite well once you get all of the build up off and your down to just the discoloration.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
