Removing Ignition Fuse
SaiyanFury
61
Jun 10, 2005
Bell, Florida
OK this is a stupid question but an earnest one. I want to prime my engine with oil without spark firing so it doesn't start up but I'm not sure what fuse to remove. Can anyone here give ma an answer? I'd like to prime it by turning it over with no spark, and I know it's doable. We did it when we rebuilt my engine a few years ago, but it hasn't run in 1.5 years. Can anyone render help?
There is a reason you don't just pull the plug from the coil. Disconnecting the MPI fuse cuts both fuel and spark from being delivered into the combustion chamber while pulling the plug to the coil only cuts spark. That means that fuel is still being delivered to the cylinder when you don't need it. You'll be wasting gas and maybe even flood the cylinders by only disconnecting the coil.
