420A Removing 420a wiring harness question
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
Hey guys, i have a quick question on my 420a. I'm in the process of removing the engine because i'm taking this engine and swapping into another eclipse. I started unplugging some harnesses and i thought maybe just unplugging the entire wiring system from the ecu would be quicker and easier, you know the giant plug that goes into the ecu. That way i could just pull the engine with all the wiring still attached to the engine. And leave the ecu behind. My question is if this is the way to go or not. Thanks
I don't see any issues with doing it that way, just watch for any part of the harness that may go into the cabin of the car.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
