Rediator check lemp's on, please help.
civickiller
119
Nov 6, 2004
Salem, Oregon
My rediator check lemp is on :cry: , I checked everything and rediator looks ok. What could be wrong? It's been on for 3 month now and no broblem with it what so ever. Please give me suggestions.
How long since your last radiator flush? Who did it? You know to check the fluid level at the resurvior and not by taking off the radiator cap, right? Sounds like a bad (or dirty as stated above) sensor, but I'd make sure before leaving this unchecked for another 3 months. Bad radiator sensors lead to all sort of other costly problems that could be fixed with a $5 sensor.
dave99gst said:
clean the sensor at the bottom of the coolant overflow bottle
I will clean the sensor, hope it will help. I also have check engine lamp on recintly. I went to autozone and they told me they can only tell if my car is 97 and up, but mine is 95. Once i replaced bov vacume hose and it disappeared, then it appeared again. Anything i can do about it?
That's the most retarded thing I've ever heard. They can definitely scan the codes for you.
