1G Recommended Power Steering Pump?
You can buy a rebuild kit. There are detailed instructions if you search here. Otherwise look for a rebuilt one at various parts stores, Rockauto has them, or find a used one. Assuming the leak is not from a line or fitting?
I'd recommend a rebuild/seal kit. They are pretty simple to rebuild if you take your time and observe the orientation of all the parts.
If you opt for a reman unit instead, get the reman installed and working before turning your old one in for core. Sometimes they leave off critical components that you have to swap or you get a DOA.
I have a 1990 Mitsubishi Eclipse GS 2.0L automatic FWD. The power steering pump is leaking and I’d like to know what my options are for replacing it. It’s a pretty serious problem as it’s slowly leaking onto my alternator.
If it's leaking at the top piece (common) that isn't the pump its the orings or the line typically.
Great point. Have you determined where the leak is coming from?
I have a Cardone rebuilt from Rock Auto. It works fine. I did need to obtain one if the pressure line orings, and that was a bit of magic. NAPA had one that worked!
