Recommended boost
RyanDSM
Aug 23, 2002
Alright. I want to run about 16psi daily on 92oct gas, I have the following mods:
ACT2600
S-AFC II
PocketLOGGER
3" HKS Catback
3" Testpipe
Hacked MAF
TurboXS RFL BOV
Strong stock 14B
Assuming that after I have it tuned I have 0-3 counts of knock through the band, I should be running efficiently and not just pushing hot air, correct? I'm almost sure this will be fine, but I don't want to push too much PSI for my near-stock setup.
Basically just looking for reassurance that my setup will be running well :)
I would definately recommend getting a Walbro to be safe. It's only $100 vs $1xxx if you blow your engine from running lean
I also suggest a better fuel pump. The fuel pump should allow for 16PSI. I would leave the boost at about 14PSI until you get a better pump. Better to be safe when messing with the boost.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
