Recirculated BOV Problems wont Accelerate
r3kU
41
Dec 18, 2013
Fontana, California
Just swapped a Dejon Intake from my Injen Intake and recirculated my bov, The car seems like it does not want to accelerate itll lock on rpms, Like 2k-3k then it goes back to 2k or locks at 3k once it gets past it itll just lock at 4k and itll stop from there .. Any clue what im dealing with?
I don't think I have any boost leaks the car wasnt running like this before I recirculated my bov I was just running a vented bov cause my injen intake had no port to recirculate my bov and that is why I swapped it for a dejon because it had a recirculate port.. And I only have two lines which I used a T to hook up because the intake had only one port
I added a T to the new dejon intake port because it only had one port while my old injen intake had two ports so i used a T to connect two of those hoses into one..
nothing should be T'd coming off the intake tube.
1 line (medium one) goes to the valve cover
1 line (smallest one) goes to the boost control solenoid
1 line (the fat one) goes to the charcoal canister
They can all be deleted and capped off though. (If done correctly)
