Rebuilt head question?
skeeterfishin
36
Jul 19, 2006
frankfort, Indiana
Hello all, I have a rebuilt head with about 2000 miles on it that has been sitting in my garage waiting for me to finish the bottom end. my question is that since this head has been sitting for a while will the lifters need to be bled prior to start up, the cams have not been removed. just wondering since it has sit for several months.
Thanks in advance
hopefully the head was sitting on a flat level surface. aluminum is soft enough to slightly warp if not siting right.
to answer your question. It is always good to pour some oil on top of the cams and the rest of the head. spin the cams with you hands a few times. that should be good enough. when you do install it i would suggest to unplug your coil pack and turn the engine over without starting it this will help coat the internals with some oil before starting.
hope this helps
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
