Rebuilding my trans needs some advice
talontsiboy24
868
3
Mar 28, 2009
60457, Illinois
I will be rebuilding my trans with a ipt performance trans rebuild kit with a translab shift kit. i have a 97 gsx automatic. what kind of trans fluid should i put in there once i put the trans back into the car? should i go with amsoil synethic? also how long does it need to break in? if i rebuild the trans should i buy new solenoid kit also?
I believe the factory fluid is called Diamond SpIII which is pretty expensive from the dealer. Castrol makes one they sell at the parts stores that is compatible. Its about $5/quart, too. Works good for me! Stay away from old fluids like dexron, typef, etc. They dont have the correct friction lubricants for the types of clutches/etc in the trannies.
I have no personal experience with Amsoil in a dsm, but it is a high quality oil, but very expensive
well i think oem mitsubishi fluid would be best but i want somethin better im really thinkin amsoil but not sure yet:hmm:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
