Advice on rebuilding my dsm.....worth it?
williamdsm
87
Jul 4, 2007
Newfield, New Jersey
Hey guys. After reading around here on the forums and seeing all the problems people have with their DSMs, I feel like building my car is almost out of my league. I read problem after problem with these cars, some with no solutions. I've never dealt with a turbo car before.
I have a 91 GSX sitting in my backyard that I have pulled the engine and transmission out of some time ago. It just sits now and i was thinking of rebuilding it since I have everything. Mind you, it's just a stock rebuild, nothing crazy. I will be sending the block out to be prepped, also reusing the crank and rods, while buying new stock pistons and rings. The biggest upgrade I may do is an Evo III 16g turbo, and FMIC.
The current mods on the car were there when i purchased it. 2g MAS, rc550cc injectors, apexi 3'' turboback exhaust. At the moment it has no tuning or data logging device.
I'm not rich nor do I make great money. The idea was to put a little money into a car that I already have, and have something fun to drive around in. Is it even worth it to start on this project? I mean, has anyone ever done what I want to do, and run into minimal wallet-emptying problems?
It's not that I want to be cheap.....but I'm working with a very small budget.
its very do-able, you have to be smart about things though, make sure all your fluids are fresh -- maintence is key,, DSM s are reliable as long as you take care of it before you beat on it-- make sure you break that motor in correctly -- look up how to do that, and then do your reasearch on ecu management and fuel amounts for that evoIII 16g -- you can have a nice reliable fun car on a budget,, do everything right the first time and youll enjoy the experience
just look up all your questions on the search button and you should have no issues:hellyeah:
good luck man
2G MAS + 550cc Injectors on a 1g is about perfect as far as fuel trims and WOT goes, so he can get by without fuel management and tuning...for the moment.
Thanks for the quick response, Machine! I appreciate it.
Zigg, will I need to tune if I upgrade the turbo, though? What do you mean for the moment? Thank you very much for your input, but could you explain a little more for the DSM noob?
If you have the 550s already and you buy a 16g and fmic, you should be able to get by without a tuning device till you can afford one. As long as your running low boost say 10-14psi
Thank you. What are some recommended tuning devices that are pretty user and noob friendly?
I came across this video, and this product seems pretty user friendly. Any advice on this?
YouTube - SM-AFR Wideband O2 Air/Fuel Controller Introduction
