Rebuild Question!
GSX'er587
183
May 9, 2004
Novi, Michigan
Well, the time is here for a rebuild for my 95 GSX. I was trying to get opinions on what is necessary/unnecessary for supporting a 20g..and yes all the proper fuel delivery/tuning mods will be done before installation. I know the stock bottom end is capable of handling around 350hp but while im at a rebuild, why not go all out? So heres what i was planning..
6 bolt block w/ 2g head
JE pistons (.020) and rods
ARP head studs
ARP main studs
Cometic Head Gasket
HKS Cams 264/272
3g lifters
Bronze Valve Guides
New Engine Gasket/Seals
1mm oversized valves (retainers necessary too? i dont planning on revving higher than 7300)
Balance Shaft Removal
Decked Head
**Is an angled valve job or ported head worth it? Is tehre anything else you guys think would be a good idea to have and get out of the way during the rebuild? Thanks :thumb:
Clevite Bearings i think is what most people use. Everything looks fine. Make sure you clean up your engine bay before putting back the engine.
QUOTE]
Will this be an everyday driven car? If so id reccomend going w/ Wiseco Forged pistons instead of the JE's The work better w/ the expansion rates in a street car. Also are you using 1G bid rods or a forged rod? Scat rods are an excellent choice for a great price rated at 600+ HP. I like there design better than the eagle h beam rods. also ive heard alot of negative things about the JE pistons and that eiter Wiseco or Ross or Venoilia is a better piston, but if its an everyday car, then id reccomend the Wiseco Pistons. Just my .02
Is it really worth it getting aftermarket pistons? Or, should i just have it built back to specs? Stock internals can handle a 20g properly tuned right?
Dont mean to be bumping, but ive had a huge change. I'm gonna be running the evoIII 16g instead. Is it necessary to buy aftermarket pistons, or should i just keep it all to spec? From what i've seen people have been just under 300hp and i know the stock block can handle that, so is it worth it? :dsm:
