rebuild head or relpace?
daindaniel
Mar 1, 2010
fort campbell, Kentucky
hey my name is daniel. i just bought a 1990 eagle talon turbo car. the car is completely stock. the previous owner broke the timing belt and then replaced it with it being off timing. with that being done it bent 8 of the valves. i have the head off and just wondering should i replace the whole head for the 265 ebay wants for one or should i rebuild it.
well depends on what your goals and budget are....
it will cost more than $265 to have your head rebuilt...
this is what your looking at having done....
http://www.dsmtuners.com/forums/newbie-forum/341218-how-change-valve-guides-4g63t-head.html
then the head will ned to be surfaced, DO NOT let the machine shop belt surface your head...
http://www.dsmtuners.com/forums/cyl...0613-why-not-let-your-head-belt-surfaced.html
this is how it should be done...
http://www.dsmtuners.com/forums/new...face-4g63t-cylinder-head-mls-head-gasket.html
then the springs will need to be tested...
http://www.dsmtuners.com/forums/newbie-forum/341287-how-test-valve-springs.html
and since the head is off you may want to do this mod...
http://www.dsmtuners.com/forums/newbie-forum/341028-4g63t-head-oil-port-mod.html
is the ebay head a reman? or just a used head? if used, you may want to still have the springs checked and new valve stem seals installed
