snowborder714
Moderator
- 16,189
- 471
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
I picked up a Cyclone intake manifold and would like to rebuild/refresh the whole thing. I have new OEM inner gaskets, so that part is taken care of. I tried removing the shaft the other weekend, but am having issues removing all of it. The shaft is 2 pieces, utilizing a slip joint in the middle (like this: [-). I'm able to easily remove the outer portion of the shaft, but the inside portion does not want to come out.
Has anyone ever completely removed this, or do you usually just remove the outer portion to replace the seal? And if someone has replaced the seal, what size is it?
