2G rear wiper arm
dsmkid2
89
Aug 13, 2013
haverhill, Massachusetts
I have a question how do you install a rear wiper arm on a gst I swaped my trunk because it had a big rust spot and and I swapdd it with a trunk from from a gs I didnt buy a gs trunk it was given tome for free so my friend bolted up the new trunk and removed the rear wiper but I didnt see hos he did it so nos the new trunk is on but something seems off about the rear wiper the black ruber thing that wraps around the metal piece is gone I dont think this trunk csme with it kinda just looks like a metal circle with a screw sticking out
I also deleted my rear wiper, I never got any good use out of it anyway. Except i JB Welded a plate under neither and used Bondo to fill it in
I dont know when I see it like that it looks out of place LOL so could I just pry that rubber piece off from my old trunk to the new one
Yes, you can swap the rubber seal from your old hatch to your new hatch. I would recommend putting some rtv sealant on the seal so that you don't have a leak.
The picture you posted looks very odd. That piece sticking through does not look like it should be there. I just had my wiper assembly off to fix a leaking seal. On mine there was the wiper motor under the hatch with the bolt sticking through the rubber seal, nothing else.
