Rear wheel wobbles!!
jasoncitrano
600
Jul 10, 2004
schaumburg, Illinois
Ok so i'm driving with a group of friends right and they are behind my car and we get to a light and they tell me that my passenger side rear wheel is wobbling back and forth...i don't feel it inside the car at all and my alignment is good but they said it shakes a pretty good amount? any idea what this could be i doubt it's the rim becuase when you put a diff rim on it still does it..any help thanks
I have exactly the same problem! :D That must be your wheel bearing... at least that's my problem! A cop even pulled me over because he tought I was going to lose my wheel! At first I thought it was the rim because I hit a curb but even with another one, it still did it. By the way, that accident caused my wheel bearing to go bad.
But you can't just change the bearing, you have to buy the whole hub assembly! $193 cnd here! :cry:
And I suggest you repair that asap! Mine was so f!@# up at the end, that the brake rotor ended up grinding a good portion of the caliper bracket!
