1G Rear Toe Adjust
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
Is this bolt responsible for Rear Toe Adjust ?
If Yes, how it works?
I have to screw or unscrew that bolt to change rear toe ?
I also have adjustable rear upper control arms to set camber.
Normally if it is not frozen you would loosen the nut slightly and turn the opposite side, which is the cam side.
The upper arms have cams and that adjust the camber in the same fashion. Loosen the nut and adjust the cam. If you have adjustable upper arms then you should have the sleeve to adjust.
Also I would not recommend touching those things without being on alignment rack. But if you know and understand how alignment works then you can measure in front of the tires and rear of tire and compare the values and less distance in the front would be toe in or more space in the front it would mean toe out. Normally you would need to be toed in in the rear slightly. Normal values are 1.5 negative camber in each side and .15 toe in on each side. Those are stock numbers if I remember correctly. Now if you doing this at home then you would need to conver it into inches and that I can't help you as I use the machine to set alignment.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
