Rear Tail Light Conversion
Eclipsetzzz
Feb 23, 2015
Lonsdale, Minnesota
I want to convert my rear tail lights to blink like the new mustangs and am wondering if anyone has done this or know where I can buy a conversion kit to do this. Thanks
pretty sure I seen a YouTube video of this being done, but I don't think there is any conversion kit, all custom made.
You are probably thinking of this 2G video:
To get that effect he had to build flat panes with LEDs on them and wire them all up to a controller box. These days something like Arduino or TI Launchpad can be programmed to control the lights, or if you want just the Mustang style turn signals just wire in an aftermarket Mustang sequential flasher ("sequential turn signals" is the technical name for that pattern, by the way). They are pretty easy to find. Or you can even make a set. Pretty much all you need is some transistors and capacitors. There are plenty of schematics out there too.
There are kits out there that adapt older mustang tail lights to be sequential I suppose you can just wire that kit into your car.
If you are good with wiring you should be able to get a sweeplite mustang taillight kit or any other sequential taillight kit and splice the plugs for and eclipse/talon taillight socket.
