1G Rear Coil Spring Isolator - 1G
Fabs
May 3, 2012
NOg, Arizona
Hello everyone,
I'm trying to find the rear coil spring isolator but all I found is for 2g; even searching in here.
Any luck with something that may work with a little work?
Thank you so much for your help.
F.
Anything like these work in place of the originals???
Thank for your answer, I looked at them but they look totally different from OEM.
Trying luck here, maybe someone already experimented with this.
Try contacting Miller Import Parts, they are a supporting member and part out cars all the time.
Also, @dacowgod , has had several part outs lately also. Try contacting either or both of them for the isolator you need.
You are looking for one or I would say to post up a picture of exactly what you need.
Good luck!
Marty
