2G Rear camber adjustment
Slow420a
36
Jun 26, 2003
the other day while my car was on a lift getting exhuast put on i noticed that the back tires have alot of negative chamber, will the 15$ rear chamber adjustment fix this?
I think i've got a pretty good grasp of what the rear camber kit actually is
it's an assload of thick metal washers and 4 long bolts. these go on the rear and you can probably reuse the stock brackets. just place an equal amount of washers behind the brackets and rebolt with new bolts.
i'll be doing my rears tomorrow with the ingalls kit so i'll let you know how that goes
Yep, that's pretty much sums what the rear kit does. The ingall brackets though, are adjustable in themselves. The center bolt in the brackets can slide either more toward the car our more toward the outside, thus, mimicking the same effect that two layers of washers have.
My car has lotsa negative rear camber, the suspension is stock. But im getting tired of going throught tires so damn fast because their wearing unevenly. Any ideas on y or how to fix it. Also anyone else with the same problem
