Really Random replacement parts
91TalonTC
Feb 24, 2011
Carol Stream, Illinois
So I have been rebuilding my 91 Talon for about 6 months now on a huge budget and am now almost done with it... really exciting stuff and all, but the parts I need seem impossible to find.
for starters, i need the driver's side radiator fan assembly, which I can't find anywhere.
I also need the oil filter stud, and that piece between the filter housing bracket and the filter housing bracket itself (I think it is an oil cooler?) either way, I can't find the housing anywhere and it's leaking.
Also, I removed the charcoal canister because it was dry rotted away to virtually nothing anyways, and want to know if its even worth getting a new one if I don't need to take it into emissions.
Lastly, I think I need to get the engine loom re-wired or a replacement installed. I have a replacement but no time or equipment to do it myself, so if anyone has any idea roughly what a price would be or even who would be willing to do it (I've called about 20 different places and they all didn't want to deal with a wire harness replacement).
Any websites you guys know of for the stud, cooler, filter housing, or radiator fan assembly would be greatly appreciated if you could let me know, because I have been looking everywhere and haven't found anything, and I just want the car back on the road.
Thanks all!
check extreme psi for the OFH they should have them in stock. For the wiring harness your best bet is to do it yourself. We can help you threw the trouble shooting if you let us know whats wrong with it. You probably wont be able to find a replacment wiring harness unless you find one in the junk yard. whats wrong with the wiring? you should be good without the charcoal canister.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Hello and welcome to the forums
You can pick up a fan from our classifieds section, there are many partouts. Or you can pm me as I have one
Give STM a call about the oem studs you need. Very helpful of oem items.
STM: 90-99 DSM PERFORMANCE PARTS
If you do not need emission then just scrap it and loop the egr found on the intake manifold.
You can loom the wire harness your self. Loom can be found for cheap at any auto store or even wallyworld
Good luck finishing the build
Stud and filter housing http://www.extremepsi.com/store/product.php?productid=22580&cat=0&page=1
http://www.extremepsi.com/store/product.php?productid=22664&cat=0&page=1
Rad fan assembly - local auto wrecker or classifieds
Oil cooler - local auto wreckers or classifieds or if you want to spend money http://www.extremepsi.com/store/product.php?productid=22575&cat=0&page=1
Emissions canister - don't worry about it, unless you have to pass smog, and even then, lots of people pass without it. Just make sure you capped all unused vacuum nipples.
Hope this helps!
