99GS Spyder Top Replacement Parts
tim3500
Apr 14, 2013
Horntown, Virginia
I have a 99 eclipse spyder and the top is not working properly.
When I open the top it clicks when it is almost all the way open and then fails to close the top on its own. I took apart the side that was making the clicking noise and found that two teeth on the larger half circle shaped gear are significantly worn causing it to skip when the motor gear hits them. I need to replace this gear on the passenger side. Does anybody know where I can get this part from? I tried looking for it myself but I haven't had any luck finding it. I appreciate any help where to look. Thanks.
Are you sure the shear pins in the motors are still intact? Had that happen on my 97.
